guzzimike
- Joined
- Jul 2, 2009
- Messages
- 1,353
- Reaction score
- 8
Ok, so I got my car back from the tranny shop (the TF 727 trans was pulled off, rebuilt and re-installed), and I have a problem that did not exist (Ever) before the work was done.
When I turn the key, I have a 10 - 20 % chance that it starts up without issue.
The other 80 - 90 % is a chance that the Starter Motor solenoid sounds off (Clicks audibly), and the engine physically tilts over about 1/4 Inch as if the Starter is trying to spin the flywheel, but the Engine does not start.
It acts as if the engine was frozen. No spin, no cranking over, no nothing except what I described.
If I do this repeatedly, maybe by the 7th or 8th time the engine will crank over normally and run fine. I've tried to start with the shifter in PARK and also in NEUTRAL. Same difference...
Battery is Good, Grounds and Positive are good. I connected a Fluke VOM Meter, and at rest, the battery shows 13.2 VDC. When I Crank the starter, it goes to 12.5 VDC, so that is all good..
My question is this...Is there anything that the Tranny shop may have done that could have disconnected or Misaligned something to cause the issue..?
I guess that this malfuctinon Could be a coincidence and that my starter motor could be on its way out...but it's a helluva concidence if true.
