I picked up a '99 5.2 with 154,000 miles. I heard the motor running before it was pulled. Sounded good. Still would like to do a rebuild. Does anyone have a bottom end kit they recommend for bearings and rings etc.?
This will be going in a 1967 Plymouth Fury III. I've been lurking over here as there are more magnum swap posts than on forcbodiesonly. Looking forward to the process!
The plan is to swap the intake, new small cam, and new seals and bearings. Going with the V-belt setup.
