[WANTED] STD 340 Pistons
Looking for the early 340 pistons in STD size. The ones that rise into the chambers.018 inch. I don't have a part number but will post one later.
I have a used set of factory standard bore pistons with the wrist pins all appear to be in good shape.
PM me if you want more info
Those are late model 8.5:1 pistons. I also have an NOS set of those. I don't want nearly that much...
No kiddin. Highway robbery for a plain old cast piston. I could see 100.
You could have these for $50 plus the ride
They came from a 340 that was in a 69 Swinger
Edit: Plus they come with a new set of rings that are already on the pistons.
If the OP does not respond within 24 hours they are yours
Ill take them .They sound like exactly what I am looking for. I was goin g to post pics and part numbers but if they are oiut of a 69 they are it. I think the '018 "sticking up" in the combustion chamber is enough of an identifier. :) I will PM you to work out details.
