Steering Column Insulator
mopowers
West Sacramento, CA
Does anyone know where I can find one of these? It's an insulator for the steering column on a 66 Dart.
Looks like a motorcycle inner tube might work. Never have seen one available before.
Ask a phone guy for 12" of "collar tape' it is rubber tape thats about 1mm thick. Do 2 wraps.
'Plate 19-14-23' isn't even on my 65 Barracuda, iirc it just goes through a hole in the firewall, anyone confirm? Im at work now.
My 1964 & 65 didn't have that, as I recall, "as found" by me. I probably used a strip of rubber. If you want something which encircles it, you can buy very large ID heat shrink on ebay.
I have electrical tape before and just built the column up. It works fine.
What am I missing? Looks to me like the OP can just re-use the insulator he has. All it needs to do is provide a thin rubber layer between the dash clamp and the column jacket. Most of it will be covered by the clamp; a couple of small splits on the outer edge won't hurt anything, and they can be positioned where they won't show even if someone were to look under the dash.
The one in the picture is for another car.
