Steering column options?
gregsdart
mn
I have a 65 Dart, and need a column that I can use in the fabrication of my coilover rack and pinion conversion. Fabricating the engine compartment end shouldn't be a problem for me, I just need to know what columns would work that have no column shifter. B body? C body? I would prefer a tilt, if possible. I have a stock dash, so the column diameter needs to be the same, amnd I could change the wiring, if I need to but it is currently a 66 dart wiring plug for the turn signals. What is out there? Thanks, Greg
You could call IDIDIT, and ask for Kellie Weaver. She would be able to give you options on what they have available or custom make a column for you. Here is the # 517.424.0577
Thanks
James
