Just wondering if anyone sells a rebuild kit for a steering column for a 68 Dart? Took a floor shift colomn apart that I bought and I think that it has be redone before I put it in.
Not aware of any kits either. The upper bearing is most likely fine but if not, the one pictured should work and can still be found through an internet search:
Look at the turn signal cancel cam. A lot of times they're broken but a repair kit can be purchased at Napa. Part# ECH DL6120 (or DL6125)
most of the bearings i have come across are good but need cleaning.....i usually soak them in laquer thinner to clean them up and then re-pack them with grease.
