flathead31coupe
it seems that my alt will only charge at a high rpm, or while driving at a faster speed thoughts....its a stock early charging system with the regulator on the firewall
The car hasn't always had a low voltage problem. It worked just fine when it was new. Voltage drop occurs at aged weakened connections, bulkhead, amp gauge, etc...
Throwing a higher voltage at the system will hide the actual issue.
The OEM type mechanical voltage regulator can be a player in the low voltage issue too. That exact OEM design may or may not be available today. A modern solid state regulator designed to maintain a slightly higher system voltage is readily available. Google VR128thanks I will get the info asap
