73Swinger18
edited...
Not sure if it's just the camera, but the cap looks as if some of the terminals are firing of the top instead of the flat side....?????
It is discolored on the top and side of the cap points. It's a custom dual spark systemNot sure if it's just the camera, but the cap looks as if some of the terminals are firing of the top instead of the flat side....?????
The contacts look good, just that burning around the rotor tab. No signs of burning through the rotor body. I ordered a new Accel cap and rotor.As to that rotor; I read you said it was good, but the only time I ever saw a rotor that bad, was when it was firing right through the material, to the dizzy center-post. And it only did this when the coil was called upon to work hard, as in full load-WOT. The rest of the time it ran fine. I think I would have a real close look at the inside of it and also the top of the dizzy where it slides on. Then I would throw it away.
No, I'm not talking about the contacts. Flip it over upside down and look into the center tube with a MagLite. It's not often you can trace a problem like yours to the rotor, so I know you have ordered a new one, but I'd sure like to know if this one is as bad as it looks. Don't throw it away! After you get your car running right, swap this one back in and see what happens.The contacts look good, just that burning around the rotor tab. I ordered a new Accel cap and rotor.
https://m.summitracing.com/parts/acc-8321
Flip that rotor over and see if there is any carbon tracking on the inside.
Check the ends of your coil wire.
All looks well.
It doesn't wipe off. There is nothing on the underside, not even a speck. Maybe the contact on the rotor is not properly seating on the center conductor and flashing causing the burn marks on top of the rotor. There is some wear on the cap center conductor. It is the same type of wear that I had on another NAPA brand cap. Maybe it's normal, maybe not. I got my new control module, cap, and rotor today. Hopefully that float comes soon so I can try it out.OK, I hear you. But I think something is going on there. IMO, that is a lot of arcing going on at a place where there shouldn't be any. Does it wipe right off?
Well the Round Black mark on the rotor , and the Shine on the carbon tower, say they were in intimate contact with eachother. If the wires are good and the plug gaps consistent then there is only three reasons for that stuff to be there; 1) the gap from the rotor tip to the tower at the time of firing was almost too much for the coil and it put everything into driving the spark that it could,which created a huge fireball in there; which is not attested to by wear on the towers and rotor tip, or 2) The spark was happier going to the rotor-body than to the tip, or C) it was there when you first put it in there.It doesn't wipe off. There is nothing on the underside, not even a speck. Maybe the contact on the rotor is not properly seating on the center conductor and flashing causing the burn marks on top of the rotor. There is some wear on the cap center conductor. It is the same type of wear that I had on another NAPA brand cap. Maybe it's normal, maybe not. I got my new control module, cap, and rotor today. Hopefully that float comes soon so I can try it out.
Those cross to Autolite 65.RN12YCs. Convert the Champion 12 to Autolite, if you like those
How did that unit work out for youJust ordered this control unit. JEGS Performance Products 40805: Blue Ignition Control Unit 7,500 RPM | JEGS
Hope it helps! Will the coil I have work or should I look for another one?
