ScampMike
Despicable Damn Yankee
RIGHT ON!!I have a switch in my hand that will work for you. On to the left, left off to the right, right on. Right off to the left. left on.
pic?I have a switch in my hand that will work for you. On to the left, left off to the right, right on. Right off to the left. left on.
Oops, missed the link...Yeh, don't see a need for that either.
Not sure deciphering there data sheet... I think this one functions as an 'A/B' with no center position. For some reason they downgrade it to 8A for DC? They make this with just about any configuration. With or without center. Any position NC or NO, Momentary or not... I would call them and be sure I got the right one
let me know how much you want for it!
I went over that in my first post on the subject. Just so you don't think I'm a klutz.Just need an A/B switch
AC current goes to zero every 20 milliseconds or so, putting out the arc. DC doesn't do that. The gap in open position isn't all that long, which means the arc lives for quite some time, eating away at the contacts, killing life expectancy.Yeh, don't see a need for that either.
it's ok -I went over that in my first post on the subject. Just so you don't think I'm a klutz.
And who might that be?
I'm pretty sure I can find one over here. I'll try that first at least.
Wifi would be a better investment than a turntable LOL
then you can say you live in 2017 and beyond LOL
LOL her ***? Did the fire department send out the hazmat team?
kidding? I STILL HAVE ONE I want to get rid off! Seriously man.Don't use Howards Cams, Ray was kidding...
Mitch found that his oiling problem was too small of an oil hole in #4 journal...
Makes sense. But then a lot give same rating for both...AC current goes to zero every 20 milliseconds or so, putting out the arc. DC doesn't do that. The gap in open position isn't all that long, which means the arc lives for quite some time, eating away at the contacts, killing life expectancy.
essentially, yes.
heres the situation. the 78 w200 I have only has a 20 gallon tank. I have room on the other side of the frame for a 2nd 20 gallon tank, which I also happen to have. the thing sucks gas so badly, I can go about 80 miles on 20 gallons. so I want to add use this 2nd tank, giving me 160 mile range if that makes sense. I've also kicked this idea around for the dart as well since I want to take it on long cruises.
Geez, what's with the scammers lately? I've been getting all sorts of Nigeria-style e-mail in my spam folder the last week or so. Haven't seen any in years! Gmail usually deletes most of it before I even see it.
