VonCramp
I have an A833 Hemi 4-speed 18 spline a-body transmission. I am running aMcCleod clutch and pressure plate. I recently pulled the 340 to do some work on the lifter valley. I put the motor back in the car and now it makes a really horrible rubbing sound when I engage the throwout bearing against the pressure plate when the car is running. Definitely a rotating noise as the engine is running and clutch is engaged. I would be happy to supply a video, but need some advice on where to upload it here. Thank you! Also, the bearing, clutch, and pressure plate have about 300 miles on them. They were all new upon installation.
