Marcelo Dart BR
Well, last week the Dart was ok, everything fine. When I was getting into the garage it started to stumble and died. Then I started it again and parked.
Today I tried to start the car but nothing happened. If I pump the gas a couple of times it starts but doesn't idles and then dies. If I open the gas about a half and start, the engine revs to 1500 rpm for a while and then the rpm drops and it dies again, if I insist pumping the gas the carb backfires badly.
My carb is a Holley Double Pumper, I thought the power valve was blown, but I opened the carb and the PV seems to be ok.
What else could be causing this?
