Once again, it's not about "long timing", but about overlap. In otherwords, it's about how long in degrees that both the intake and exhaust valves are open, not about total duration. 1wild&crazyguy tried to put this forth before, but you would not listen.
KB pistons use .006 figures for dynamic CR ratios and that's a fact.
Anything else?
Please understand that I'm not trying to be rude, but I CANNOT reccomend a 10.5 as a MINIMUM for this cam not knowing this man in person. Can it be done? Yes! With flat tops and Magnum heads with quench set to .040" or less easy or aluminum closed chamber heads. Could it be done with open chamber J heads? Yes it can.... Here at 5280' in Denver. I'm running 10.2 with a Lunati 604053 in a 4WD Ramcharger w/3.55's and 33x12.5's and I'm running a Mallory programmable ignition and distributor with a total of 32 and no vac advance and I'm on a hare's breath of detonation.
This being said, I just may name my next Rottweiler Guiness, because he/she'll be black and tan..... :cheers:
Or maybe...... They'll be named INDEPENDENCE!!!!!! lol!
Just messing with ya!
Edit: Just threw ya a thanks for the band Iron Maiden....which is what I'm listening to right now.
