I'm putting together my 8.75 and I'm ready to fill the "diff". Does anyone know if I have to put an additive in for the sure grip? If so, what do you recommend? I checked Royal Purple and it looks like nothing else is needed.
Yes,if you have a sure-grip?you need to put in the additive!I'm putting together my 8.75 and I'm ready to fill the "diff". Does anyone know if I have to put an additive in for the sure grip? If so, what do you recommend? I checked Royal Purple and it looks like nothing else is needed.
For clutch type diffs you need a friction modifier. I use Mopar brand in which you can buy at your local dealership.
Needed in all SureGrips or Hypoid differentials.How about for the cone type sure grip...still needed ?
It can't hurt. Although without it the rearend would probably chatter when you turn a corner. Some synthetics have the friction enhancer built in. Maybe that's what you put in yours? JMO
Read the bottle of gear oil you are using, some come with the additive already in them.
Just used regular gear oil 85-90 weight. Hmmm, did hear something on the maiden voyage in the parking lot....LOL
Thank you. :cheers:
