Lars
Finally installing my Airgap on the Dart. I have the bypass hose fitting and heater hose fitting from Mancini. Should I put antiseize on the threads or silicone?
Thanks
Thanks
Another vote for teflon pipe tape..i see your using the chrome thermostat housing and its leaking,the trick with those is to get some sandpaper lay it flat and run the thermostat flat surface back and forth to roughin it up,apply a small amount of sealant to the gasket and they usually seal...
can we see the finished result?
Ever seem the factory sensors with sealant on them? It's not silicone.. It's teflon based. We're talking cooling system here, not inside a boiler...lol. And it looks much cleaner.
Can't wait to be rid of this Lokar linkage.
Why don't you like the Lokar linkage?
See how it is only bolted to one stud? Because of this you can't run a real strong return spring since it will constantly get pulled out of alignment. This caused me a lot of trouble with getting a decent idle/full throttle travel. I like the kick down cable, and the throttle cable was fine too. But their mounting solution needs a lot of work.
I have the lokar setup with the stainless steel braided lines and I must be lucky as I am not having Any Issues like your describing.. My brother has the same thing on his 32 Pherd roadster although we both have Edelbrock carbs not sure if that makes any diff..See how it is only bolted to one stud? Because of this you can't run a real strong return spring since it will constantly get pulled out of alignment. This caused me a lot of trouble with getting a decent idle/full throttle travel. I like the kick down cable, and the throttle cable was fine too. But their mounting solution needs a lot of work.
Making progress. Lost some time today cause I had to clean my work benches off some, it was terrible. Lost Friday also since I had to go get new tires for my truck, but I got new tires for the Dart at the same time, hopefully they will match my setup better. They certainly look better IMO. Please ignore my nasty engine bay, I promise I will clean it after I get the car buttoned up.
Also ordered a 650 Speed Demon carb for it on Tuesday. Should match the cam and intake a little better then the Road Demon that was on it, plus now I have a Road Demon for my truck!
