nm9stheham
I'm used to TC's that don't provide much engine braking at all. But having driven a late model Challenger with auto it has the feature in manual shift mode that it provides engine braking; the RPM's drop only about 150 rpm when you back off, so it behaves pretty closely to a manual in that aspect. And I had an '85 Chevy 3/4 ton 6.2L diesel with a 350 3 speed auto that would provide engine braking if you manually downshifted to 2nd. That was a totally non-electrnoic trans.
So is there a TC around for a 904 that will do the same? And how are TC's changed to provide engine braking?
Tx in advance!
Tx in advance!
