hey man, glad you're back! no one will be able to wipe that SMILE off your face when ya driving it!
I know everyone has advice for that surface rust, BUT......go to a TrueValue hardware and spend $9.99 for a qt of OSPHO, it is a phophoric a cid based product. pic you a panel and go after the surface rust with nothuin coarser than 80 grit , just by hand if necessary..... and clean it up some. or run a wire cup hooked to a right angle grinder,,,, wipe it down with OSPHO and ley it sit outside in the weather is fine. see what it does to stop the death.
BUT, do not even think of applying any type primer or paint till it has TOTALLY dried and cured and be warned, I have seen some tractor enamels puker some applied over it especially if not cured. if you like the "rust" look, the Ospho will kill the rust, leave a protective coat of ???? and will still have that rust look but the color of the rust will be different. I say, just try it, Mikie, you will like it!
doesn't it help to have car friends to hang with!??
