[FOR SALE] ThermoQuad ready to go
demon sizzler
Rating - 50%
1   1   0
ThermoQuad, late model completely re-calibrated for a stock or mild 273, 318 or stock low compression 360. Has been tested on a stock 360.
The following mods and work was done:
primary throttle shaft bore re-bushed by me, using K &S brass tubing stock.
1)bushings were turned and machined on my South Bend lathe and I fabricated, hand fit to the shaft and bore,
2)carb was completely taken apart, cleaned,
3)re-jetted primaries, 2ndaries and re-calibrated for non smogger performance, and all 4 circuits re-calibrated for max performance and gas mileage,
4)brass floats installed and all new gaskets and kit parts,
5)hi temp ceramic cast aluminum paint used on all metal parts to protect surfaces.
Carb is ready to go, just bolt on and adjust main idle speed, idle mix screws and adjust choke and install fuel line. This carb would be good for approx 20
over a stock smogger carb.
price is $165 shipped in the lower 48 states. Pm me for additional pics and info, David
Item located in metro Atlanta Ga
