These connectors available anywhere?
moparspares
Scarborough, Qld
Pulled my steering column out and the electrical connectors are junked. It was held together with a rubber band and electrical tape. Can i buy these anywhere or do i have to rewire the whole lot with different connectors.
Sorry, "if they are" I know not where. You COULD (cough gag) replace with GM style which seem to be
If you found a used steering column you could use those but column would have to be cheap to justify it
Another approach. Put a want ad here, but you do not HAVE to use the original connector. You could look for a "more conventional" Mopar connector using the flat blade connectors because you can GET the packard 56 terminals.
Maybe a member here has an old harness he' d be willing to cut? One candidate might be the rear tail connector in the left kick panel.
My signal switch connector wasn't totally shot but the lock/keeper did snap off when separated. A zip tie has held it together for about 6 years now.
