I feel for the guy but in this day and age of "the internet" if he'd just done some research..............
There should be a law against non Mopar guys owning them.
Amen to both above. I will say if they haven't been apart in 50 years it takes some work AND THE RIGHT TOOLS to quote RustyThe key is having the right tools.......and not being a frikkin crybaby.
It does. They can stick together pretty good. As long as you have that hub puller though and know how to use it correctly, you'll get them apart every time. You caint just tighten down on the tool, either. You have to tighten, smack the end, rinse and repeat.Amen to both above. I will say if they haven't been apart in 50 years it takes some work AND THE RIGHT TOOLS to quote Rusty
A member from AZ that used to be on B bodies bought a 64 330 bone stock. Even with the right tools we had a hell of a time
I bought one of these 10? years ago and recently a friend gave me a complete and parts of another two. Believe it or not I used it to yank the bearing hubs off the Dodge Ram 60 front axles for the conversion projectThat reminds me, I saw a puller on Marketplace I forgot to buy...
Yup. That's the right one. I have a real OLD one my high school auto shop teacher gave me. Made by Proto.That reminds me, I saw a puller on Marketplace I forgot to buy...
My lucky day. Guy was willing to ship and took Paypal... the only electronic money thing I have. Most don't on FB and want Etransfers.That reminds me, I saw a puller on Marketplace I forgot to buy...
No. It does not. The tapered axle housing ends are different and require their own specific bearings as well as the brake offset is different. So in order to convert those housings to a solid, one piece axle, you have to cut the housing ends OFF, weld on the later one piece axle housing ends AND get the correct backing plates and brake assemblies.Couple hundred bucks for a 65-67 axle fixes it permanent.
Good lookin' car, though.
Yep, got to use them parts up. Yours could have been a early built car. Like the 65 Darts, Valiants, and Barracuda's. Most got the 7 1/4's until late in the year and then the Formula's and HP 273 cars got the 8 3/4. But not all. My 65 Dart had a 7 1/4 with a HP273 and a 3 on the tree. That was a odd duck.And get this......1965 is "SUPPOSED" to be the first year for the solid axle rear ends right? Wrong answer. lol I had a 65 Coronet a few years back. Original car had never been altered, but it was sans motor and transmission. Guess what? Yeah, it had a tapered axle rear end under it. My guess is, like everything else, Chrysler had some stragglin parts they had to use up.
No kiddin. Don't drop the clutch! LOLYep, got to use them parts up. Yours could have been a early built car. Like the 65 Darts, Valiants, and Barracuda's. Most got the 7 1/4's until late in the year and then the Formula's and HP 273 cars got the 8 3/4. But not all. My 65 Dart had a 7 1/4 with a HP273 and a 3 on the tree. That was a odd duck.
One wheel peel. Man I could smoke that one 13" bias ply all the way down the block.No kiddin. Don't drop the clutch! LOL
I reckon if you didn't have a substantial tire on the back, it'd probably live a while. Mine will skin the hide off the right rear, but I've only done it a time or two. I've had those axles out and I know how tiny they are. lolOne wheel peel. Man I could smoke that one 13" bias ply all the way down the block.
I'll TELL you what's tiny LOLOL. Land Cruisers, generally, are known for being somewhat tough. My old 62 pretty much survived a 360, a 340, and later, a 318. Axle wise I meanI reckon if you didn't have a substantial tire on the back, it'd probably live a while. Mine will skin the hide off the right rear, but I've only done it a time or two. I've had those axles out and I know how tiny they are. lol
Same here. 1965 Plymouth Belvedere stone stock and it had tapered axles.Chrysler had some stragglin parts they had to use up.
And they put those hammer pads there for a reason. On the end of the forcing screw too.That reminds me, I saw a puller on Marketplace I forgot to buy...
