haole
New in Box. Contractor Air Compressor, Running Motor Power 0.50 HP, Tank Capacity 2 Gallons, Voltage @ 60 hz 115 Volts, Current Drawn 4.2 Amps, Free Air Flow @ 125 PSI 0.7 CFM, Free Air Flow @ 90 PSI 0.95 CFM, Maximum Pressure 125 PSI, Tank Type Hotdog, NPT Outlet (F) 1/4 Inches, Length 16.5 Inches, Height 15.5 Inches, Width 8.0 Inches. Thomas compressor model T-617 HDN is a 1/2 HP electric air compressor. It is the ideal unit for those who want a quiet air compressor, long life compressor capable of handling any (1) finish gun or brad nailer. Drawing less than 4 amps and weighing only 26 lbs., it is extremely portable and will run anywhere electricity is available. Designed for the professional, this industrial air compressor is also a favorite of the homeowner or hobbyist who takes pride in owning the best in equipment. Like all Thomas machines, it is rated for continuous use and will not burn up when given hard use. Additional uses for this Thomas compressor include: airbrushing, small spray guns, inflating tires, air mattresses, sports equipment and winterizing water lines on RVs and motor homes. Located in Nevada 89521. Grainger part number 5Z683. Paypal accepted. $ 250.00. That is half of what I paid for it. Free shipping in continental USA.
