67CBodyGuy
Active Member
I have these two brackets which are practically identical:
Left one has a couple of nuts welded to it but otherwise seems identical to the one on the right. The one on the right has a few more parts bolted to it, a rod that was cut off (with a torch) and a cable. My best guess is that it might have been for cruise control. Mounting hole spacing is 2 5/8 inches. The holes are 5/16. The hole size and spacing does not match for a small block, I don't know about a B/RB block. Another candidate might be a 318 polysphere block. Or maybe these aren't for any known Mopar engine. Any ideas?
