Been trying to figure out a ticking noise in my 340. It just started a few weeks ago and seems to be getting worse. Motor has 2 k on it but not sure on the build from the previous owner. Thought it was a exhaust leak but after some checking I believe it is in valve train. It gets worse when the engine is at operating temp and it will come and go as the rpm changes. Changed to straight 30 wt oil and it did change but is still there. They are stamped rockers and all seem tight. I pulled the lifters through the head with a magnet and they all look good also. a few of the push rods have this wear on the rocker side of them and I'm not sure if it could be the problem or if they need attention either way. Have tried to pin point it with stethoscope, rubber hose and the long screw driver to the ear it but really can't narrow it down. I did smoke test the exhaust and there were not leaks. I also swapped the fuel pump and it made no difference either.
