[Found!] timing cover and balancer
68 CUDA FORMULA S
Clarkston Michigan
I need to change the timing cover and balancer on this 1971 340 to the 1968 cover and balancer so I can use the rest of the correct 1968 parts, if you have them let me know along with shipping to 48346 Michigan.
Thanks
Bob
I have a nice used dated '68 timing chain cover. It's been degreased and glass beaded. All threads good. Ready for a new seal and paint. $95 plus ship. PM if interested.
I have timing cover, balancer, W/P pulley,dual lower pulley, Alternator brackets , Power steering pump and brackets on a 69 which is the same on 68.
Not to hijack the thread, but if someone can clue me in on what timing covers have timing tabs on the left and tabs on the right,
Thanks.
Hmmmm... reason I asked is I have a 360, the timing tab is on the drivers side, but I can't see it because the lower radiator hose passes in front. here's a pic, not pretty.
You need to switch timing covers to a pre 69 one and either use the early balancer or re mark the one you have to tdc on the passenger side.
Okay, bought this car a few days ago, trying to figure out what I have, so it's the wrong pump and radiator?
great info and help, guess i'll get #1 and mark it, appreciate the help !
An early 67 date code. correct style for 68. The cast in cover, is a 69 MODEL year version. My 67 is available to buy if wanted.
