dart4forte FABO Gold Member FABO Gold Member Joined May 28, 2004 Messages 6,031 Reaction score 2,678 Location Mesa, AZ Aug 27, 2013 #1 Had to remove the dizzy in my S/6. After I reinstalled I can't get the timing mark on the pully to move up the tab. Am I off a tooth on the dizzy?
powerwagonpaul Well-Known Member Joined Mar 28, 2010 Messages 514 Reaction score 18 Location Las Vegas, Nevada Aug 27, 2013 #2 it may be that the balancer has slipped. put the timing mark on tdc. make sure you are on the compression stroke. install the dizzy. the rotor should be at about the 4:30 position.
