72golddustermike
i am having issue with inital timing i think. i had timing dialed in where i needed it with other ecu at 30degrees T IDLE 16 INTIAL AND 14 IN CAN. i wired up street fire ignition per instructions checked with actron digital light shows 60 degrees instead of 30 and would run on a little. so i swapped wires at distributor now shows 30 like it should, msd says for digital ignitions polarity should be hooked up for most advance and analog ignitions for most retard. street fire is supposed to be digatal. any suggestions>
