MOPARJ
What can I upgrade now?
I currently run 195/65/R14's on my 76 Val. They are very tiny and make the car appear to short and low in the rear. What is the max tire size I can use for the rear utilizing the 14" rim and the max for the front. I know that the max is a little smaller on the front, as there is clearance issues when turning with a much larger unit. My goal is to give the car a more balanced look, with a slightly higher or higher stance than what it has.
