After putting about 600 miles on my new McLeod Borg and Beck clutch in my 69 Dart 340, it started making a grinding noise when the clutch pedal was fully depressed. I sent the Aetna throw out bearing to the McLeod tech department for analysis.
They said it was damaged and also showed excessive wear on the surface. They thought that it might not have had the proper clearance between the TOB and the fingers. I had adjusted the clutch pedal to 1 of free play as indicated in the Service Manual.
They are sending me a new TOB. But I am wondering if it is worth installing another Aetna TOB or going with a different manufacturer. I see Rock Auto sells Timken, SKF, and National.
Has anybody had any experience along these lines?
