Dustert73
Stripping bolts since ‘10
Hey guys, the 360 magnum in the duster has been running pretty strong the last few months. But this Saturday I was cruising along and the engine started to tap/rattle/light knock, like a valvetrain type noise more than rod knock. It was running super rough and was surging while I was trying to limp it home. I got home and pulled off the valve covers and ran it, I didn't notice anything abnormal going on and it was getting plenty of oil. I never had a loss in oil pressure, always stayed above 15-20 psi at idle and at least 40-50 while driving.
I have the front torn off the engine and the intake off. While I was turning the engine over with a ratchet there's a popping noise coming from the lifter valley/valvespring area. It sounds like a hot exhaust popping/pinging after you turn the car off. The car hasn't ran since yesterday so the exhaust or engine is cold. I tried loosening up the rockers in pairs to try to isolate the noise, but it seems like it keeps moving around. I have a video of the noise if it would help.
What's going on here? Is there a valve spring broke, or a few of the lifters bad? I can't see any obvious damage to any valve springs
