purplescamper
is there a trick to getting them on ?
We used lots of lube and a socket slightly bigger than the hex head. We were using poly boots and they were a real PITA. It worked, but it took one person holding the rod straight up on the floor while the other pushed down from the socket to the rod, and we had to be FAST.
Some people probably assume the grease is for lubrication, like a ball joint (I know 67Dart273 doesn't). I read (Allpar site?) that the earliest Mopars w/ torsion bars had no front boot or grease. In the rusty North, road salt packed into the anchor and quickly corroded. Must have been only a few years before cars started dropping down while driving when the anchor released, because they soon changed the design to filling the cavities w/ grease and booting the front. If you backup thru salty snow piles, you could corrode the rear side, though there is a little plastic disk there as a hopeful seal. Whenever I return from a Lake Tahoe drive, first thing I do is hose off the underside, and I don't think they even use salt on those roads (to protect the trout). We usually have to chain up anyway to cross the pass when snowing. Some A's, particularly later 70's ones, were stingy on welding the rear anchors. Some here who saw just a few weld spots, added a weld all around the circle. I recall a few of the skimpy factory welds broke free.... I'm not sure the darn things are even necessary the way most of these girls are driven. The rear is open, and so is the rear of the front socket. They are not exactly "sealed."
I found a few cuss words helps also!
Which ones were most effective??? #-o
