Where did you get the plates? Make em?
Aint like that happens everyday.....how many times have you seen it happen??I think it's funny alot of people talk about how the torsion bars are so great and why would you switch to a coil over I think this answers that question,
how many car were junked in the 80's due to this easy fix.
I guess thats a possibility since the original welds were only designed for stock bars anyway. Engineering a car is only math and the math for stock bars only called for what they did concerning my rear sockets when assembling it. That so called "crappy weld" worked fine for 38 years with stock bars though. Who knows?It does no such thing. The suspension load has to act somewhere. Torsion bars are just springs, they put the load on the anchors. Coil over suspensions are no different, they put that load on the lower control arms and the upper spring anchor. Does that really make a coilover set up a better design? It adds the weight of the spring into your unsprung weight (bad), and puts all the suspension forces on the lca. Not to mention taking a car that was designed around having a torsion bar suspension, and then relocating all of those forces onto areas of the frame that weren't intended to carry them.
As far as it being the stiffer springs, no, they're not entirely to blame. I run 1.12" torsion bars on my Challenger, which is a bigger, heavier car, with the same design for the torsion bar anchor. That's a 270 lb/in torsion bar, which is over 2.5 times the original spring rate. No issues with the torsion bar anchors after over 20k miles, and my car DOES have rust.
What you had there was a crappy weld, and it would have failed with the original torsion bars too. Maybe not quite as quickly, but it would have failed.
I get cha. We just installed and left the ar a little lower. The whole car is sitting lower with the hotchkis leafs. Sits real nice now and corners like a bad dog.If these are the same bars I have they should Not have been adjusted up to stock ride height! They are designed for a lower than stock ride height.this may not have caused the failure but I would imagine it definitely contributed to it.these larger than stock bars are of course much stiffer and are not able to twist like a factory bar.if one cranked it up to stock ride height the bar will not have much give left in it and will transfer more force to the crossmember.just my .02C.
I rebuilt the entire front end, Hotchkis leafs, Bilstein shocks (far better than KYB's) and sway bars front and rear, 1.08 torsions from PST (on this site). Picked up the sway bar set for about 200.00 on ebay. Bolted right up. (http://www.ebay.com/itm/160689294977?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649)Good to hear My 1" T-bars are sitting on the shelf right now eventually I'll get around to re-installing them I may make the same reinforcements as you did.Any other mods besides the leafs and Torsion bars,does your car have anti sway Bar(s) what about shocks? Just wondering I wanna make my Dart as responsive and fun to drive as possible.
