Tranny Help
dart4forte
Mesa, AZ
1961 Lancer wagon with an automatic. I need the seals where the cables go into the case. I also need a pan gasket. Is this tranny the same as the 63 and newer 904? Anyone have a source?
All the seals and parts you need, you can get from Pat Blais, (206) 365-1966. The '60-'64 slant-6 A904s are all interchangeable (plus '65 with some parts swapped), but there are filter differences between '60-'63 and '64-'65. See here for info on pan gaskets and filters.
