Transgo kit info needed
Charrlie_S
Silver Springs, FL
Picked up a used 904 trans. Previous owner, said he installed a transgo shift kit, but doesn't remember if it was the TF-1 or TF-2. I have been calling transgo all week, and cannot get thru. Does anyone have the directions from either/or both of these kits they could e-mail me? Might be able to determine which kit is in the trans. Thanks.
i got these from fishy68 (Tracy) you could probably PM him and find out more info
I'm pretty sure if you call Transgo's support no. they will email you the destructions.
The thing is, at least with the TF-2, there are at least two sets of destructions, early and late. No idea what the difference is offhand.
I had been calling Transgo all week, and just getting busy signals. Finally got thru, today. They did e-mail me the instructions. Thanks
Spring colors in the valve body, or the diameter of the 1-2 shift oil hole in the separator plate will probably be the only way to tell.
