I need a trunk pan (1 piece pan) is there a good one out there? I have not installed one before. So I would like to buy a good one the first time. The only one I have found is Year One, Paddock. Are there any others? Do these fit good?
ted_sweet said:you cant install a 1 piece trunk floor unless you removed a qtr panel or the tail panel.
70Duster440 said:You should be able to. Did it on the Duster. Personally, I'd get the one piece as that's one less seam to weld up. Buy the replacement before you cut out the old to see what you might have to leave. Take measurements or make a template for the new cutout for the filler tube. Easier to roughly cut out the sections then go back and drill out the spot welds on the frame rails and, trunk extensions, and the forward seam. The edge at the tail panel is a different story.
DusterBoy15 said:sorry bout this but do you guys know if a 70s dart sport hood will fit my 73 duster with any or no modifications? thanks
