I have no idea what that means. "We" are not there. "We" do not know what and how or even if you have checked the fuses. "Fine" is not a description of fuses.
There's just about 3 ft of wire between the fuse panel and the flasher socket.
FOLLOW THE WIRING DIAGRAM
Power comes from the fuse to the flasher socket
Look at the top left of page 8-150, the diagram for the inst. panel, Valiant
Find the flasher, has wire D1--18BK and wire D2-18R coming off it
Follow those wires
D2-18R goes directly to the turn signal switch
The second wire coming off the flasher, .............
D1-18BK goes to "W" at the bulkhead connector. THIS IS A JUNCTION
From there it is wire B1--18W (white) And goes up the page to the RADIO power connector
THIS IS A SECOND JUNCTION
From there it turns BROWN, wire X12-18BR
SO CHECK THERE DO YOU HAVE POWER AT THE RADIO CONNECTOR?
Follow that X12-18BR on page 8-151, and WHERE does it go?
TO THE FUSE PANEL RADIO FUSE third fuse from the left on the diagram.
Follow that down and off the right side of the page, and onto the next page, 8-151 towards the bottom left
!!!RUSTY!!!! Where is that dammed crystal ball???
