oem6pak
pure stock forever
Where do i get U bolts that fit my 8 3/4?
That was more than likely because they were over tightened. Torque on them is like 45 ft lbsWhat ever you do do not use round u bolts, you will crush the axle tube.
Be sure yours have the flattend area around the tube as Alaskan_ta said. I have an otherwise perfect housing that is crushed on both ends at the perch
Any idea of the part # or will they know?Original type with the flat & gripper pattern at Bulk Fasteners Listing — AMK Products Inc.
