I went out to work on the new 340 blower engine today. First order of business was to prime the oil system. I put the rod in the drill and put it down through the dizzy hole. Start the drill slowly and then speed it up. Then there is a snap and the drill freewheels. You guessed it, the priming rod snapped off in the oil pump. After that the air turned very blue. Another setback with this engine.
Here is my question. Can I lift the engine high enough to be able to lower the oil pan enough to reach in and get the piece out of the oil pump or is this a, You have to pull the engine deal?
Jack
Jack
