I like it where I can work it with my left hand so I can use the key with the other. By the way I used to make these using (whatever lever) on the choke linkage, sometimes soldered/ brazed on.......with a choke stop for a pivot on the linkage, "loose" so it would swivel, and the cable slide through. Then put a small spring on the end with and end stop. This allows some "spring" a ction so you can "set" it similar to the automatic spring, and the engine vacuum will slightly open it preventing flooding Been YEARS since I had these on my old FJ-40, SB Mopar
