Blown71Duster is correct in principle. Racks from aftermarket people like Unisteer are generally reworked OEM racks; Omni, Horizon etc for rear steer application. These racks have a lock to lock travel of 5.25 to 5.4 inches. The travel on your Mopar box measured at the pivot of the pitman arm is 6 7/16 inches. May not sound like alot but it is a difference of 15 to 18%. That translates as a huge increase in turn circle diameter which makes for a very awkward vehicle to drive. There are two possible solutions. One is to shorten the steering arms; not recommended because it is impossible to re-heat treat the arms, or to obtain a rack with a suitable total travel. The rack on my Dart is a TCP (Total Control Products) item. It came with a total travel of 6 3/8 inches. I increased that to 6 3/4 inches and it works extremely well, but it is a fairly pricey piece, plus you need a fairly good working knowlege of steering geometry and suspension dynamics to mount the rack properly. In fact, there is no real advantage in a r & p steering system that cannot be matched with recirculating ball type boxes. I used the rack and pinion only because I was installing a 6.1 in the car and did not like the positioning of the engine using an adaptor kit, and also wanted to retain the factory Hemi A/C compressor in the down low position. All of this made it impossible to keep the stock style steering box, but for general purpose I would strongly recommend upgrading your manual box, or going to a Firm Feel box if you have power steering. Just my opinion, but it comes from a lot of years of experience with these vehicles and chassis'.
