[Found!] Upper kick down rod for a 273 4BBL
68 CUDA FORMULA S
Clarkston Michigan
I have converted my 66 Barracuda 273 904 from the factory 2bbl to a commando 4bbl intake and a Holly 4bbl and I am looking for the upper kick down rod with the slide. First picture is what I have from the 2bbl, and the second and third picture is what I am looking for, fourth picture is just the diagram, looking for # 12. Please let me know what you have.
Thanks
Bob
I am also being told that I can put the entire 68 on up 4bbl kick down set up ( that's whats in the fourth picture, the diagram ) on my 66, so if anyone has this set up please let me know.
Thanks
Bob
For the record the diagram shows 2bbl linkage. 4bbl is diferent at least 67 up
I'm pretty sure I've got all the parts. I'll have to do some digging but I'll look.
I modified the one I have for a mid rise manifold so it may be to tall for your application. What manifold are you using?
Edit, I see you just need the one part?
You need the carb stud, the slot and the bent rod, correct?
