kittypancake
Are there hoses I can get so I can use my SB radiator and just bolt it into my slant 6 Valiant?
Or you could just get a slant radiator from a late 70's aspen. I don't do small block stuff, but I remember that some of them do have the lower hose outlet on the correct side of the car. I just don't remember if it pre-1970 or post-1970 cars. I know that the change happened with the redesign of the water pump.
The radiator 73AbodEE shows looks very similar to the one in my 64 Dart (non-original), except mine doesn't have the recessed fill cap, holes for the shroud, and mine has more space from the brackets to the core probably because mine may be only 1-core. I think those with the wide filler plate are intended for non-AC. They will fit a 64 if you drill 4 holes.
