furydan
not so junior member
I am running a 318 bored 40 over with kb pistons, comp 286 cam, 302 heads with an edlebrock carb and intake. I also have electronic ignition. My question is: Should I run the vacuum advance off of the timed port on the carb or the full manifold port off the carb. I have a choice. Right now I am running off of the timed port.
Dan
Dan
