Hi guys, having my Dart now for a couple of years imported from Switzerland, I was wondering all the time what the small black box with the note "CARB" on it was sitting on the right side of firewall with 2 open plugs. I took a picture of it, so everyone exactly knows about what part we are talking here...
Now, since my fan is causing trouble, I looked up info on the fluid fan drive in the manual, and I notice a hose routing diagram... mentioning the complete wiring from manifold vac and ported vacuum over that box and the by-pass valve back to the vacuum pot on the distributor.
Nice, only one issue here: the manual shows a 3 port by-pass valve on the radiator. I only have a 2 port. And there is no marking on it at all.
Some of you can help me here?
Anybody knows what the "black box" in between is doing exactly? That the by-pass valve increases idle rpm as from certain high temperatures while opening manifold vacuum is clear to me. Given your distributor is hooked up to the ported vacuum...
Thanks for info!
Thanks for info!
