Vacuum lines?
dmopar74
Kennewick WA
what do the vacuum lines im pointing at do? I removed the hockey puck manifold and ran the distributor and egr? under the carb together and then to carb vacuum. Is this right, it sure does run better. I also unhooked the vacuum lines going to the air filter housing.
