moparspares
My valve stems are not all at the same height. The exhaust valves have pulled into the head somewhat making them not the same height as the intakes. Have shimmed up the springs to installed height to maintain spring pressure. Should I just leave them like that or is there another solution. I DO NOT what to spend any money on this engine as it will be replaced with my 408 when I have saved enough moolah for my transmission. Leave it and put back together or can I do a cheap arse fix
