Valve stem seals
barracudadave67
Burlington, Wi.
OK. So Im puting my J heads back together, and have a dump question.
Im using Felpro # SS70014 OE style valve stem seals.
My question is, "how does the intake seal fit the valve guide" (its stock, not machined down),??? Does it get pushed down on the guide,??? or does it just get slid on the valve stem, and left touching the guide as the stem goes up, and down,???.
It seems too small to get pushed down on the guide.
I know the exhaust seal dosnt get pushed on.
I need enlightening.
Thanks
Dave
Thanks
Dave
It’s not a very good seal. I won’t use them. It just slides over the valve stem and rides there.
Y R
What seals do you suggest,??. I am confused buy this. I don't want to get the guides machined, they are stoc factory. I just want a good seal.
Thanks
Dave
An umbrella seal will last for 10 years or more. Use them and don’t look back. They were factory on every Mopar for decades. Kim
Do they get pushed down on the head guides,???, or just on the valve stem. the intake seals seem kind of small to be pushed on the guides. This is whats got me confused.
Thanks
Dave
As above... they are 'umbrella' seals... the oil gets on them and then is shed off the edges, away from the guides. So it does not matter exactly where they ride vertically.
I'll admit that I am a bit confused if they are smaller ID than the guide OD....
I think he means the inside of the seal seems to small. Then the seal is a positive one without the spring band on it. Yes u can push them over the guide. I don’t like how they fit that way they buldge out so I just slide them down to the guide. They find their own happy place as soon as the motor spins over. Kim
Left - umbrella, rides up and down with the valve
Right - factory style positive seal, grips guide and wipes oil from valve stem.
The positive seals expand a lot when pushed onto the guide....... that’s normal.
Either one will work fine for a mild build.
Install what you have and move on.
Those, Felpro # SS70014, are the good Viton seals. The intake seals get pushed down to grab the outer valve guide. Use the sleeve and oil on the valve tip to keep from damaging the seal. The short umbrellas go on the exhaust valves. They last forever, but I have never used them on dual valve springs.
Yes...... if your seal set has 1/2 umbrella seals and 1/2 posi seals...... the posi seals would get used on the intake valves.
And neither will usually fit inside a dual spring.
Y R
Thanks
Dave
I’m not sure why all the love for a cheap, crap valve stem seal. I understand that you have them, but so what?
If the heads are still apart, take them to a shop and have them machine the top of the guide for a positive seal. It may already be done, but you need to post a picture, or measure the OD of the guide.
Ring seal today is nothing like it was. Running a cheap seal like that just isn’t worth it to me. I mean, look at the junk **** Chevrolet sent out...a square rubber o ring at the top of the valve, just under the keeper. Worked half assed back then, but no self respecting machinist or engine builder would use those today (I hope they wouldn’t).
Thanks for all the replies.
I geuss I'm making a mtn out of a mole hill.
Heres what I have to work with.
None of these are for machined guides
Only the Felpro seals, and the intake seals on the far right are the kind that goes over the guide.
The red ones are for intake, & exhaust they also have a spring retainer on them. They do not stay on the guides.
The Comp seals are longer than the others, and do not stay over the guides.
Thanks for all the replies, as I am not an engine guy, and get cornfused.
Dave
The Fel-Pro intake seals are positive Viton seals. No machining or machinist necessary. No need for a positive seal on the exhaust valves.
Assuming the guide bosses are still as originally machined, and you’ll be using single springs.......Of that assortment in the pic, the Fel-Pros are what I’d use.
There are better seals
the neoprene fel pros end up in the pan unless you run stock revs and no long pulls up hills
check the truck listings
or the BBC HD umbrella seals if they fit inside SBM springs I've used these in BBM
there are both Silicone and Viton
other engines with 3/8 stems like FE fords
a problem with stock umbrella seals is they loose control with high rpm operation as well as high temp (center two exhausts)
what are the MP seals made of that mancini sells- the ones on the right
the next ones look like teflon seals- pass
the comp ones are suspicious
I do not see how you can have positive seals without cutting the guides
check out those mp seals
they are most likely availavle from multiple sources once you determine the materiel
Well I put them together. I used the Felpro. So we will see. Hopefully they will outlast me. I'm old, lol.
Now I have to get to work on the block.
Thanks for all the info. And advice.
I appreciate it all.
