Velcro bolts with color blind dreams
skep419
No show, all go!
Minesoooota
Curious who on here has had the same car but with the most changes over time. Not talking cam swaps or gear changes but more small block to big block, 318 to 360, NA to power adder, Auto to 4 speed, Changing colors/Drag car to street, etc.
Engines 318, 360, 5.9 magnum
Power adders NA
Transmissions 727,904, A833
Rear ends 7 1/4 8 3/4
Paint/Body Car has been the same color.
I’ll play…
Engines:
/6, 318, 340
Radiator/cooling: /6 stock, 26” Champion w/ flex fan, Ford Contour electric fans
Transmissions: /6 904, V8 904, A833, T56 Magnum
Rear ends: 7 1/4, 8 3/4
Paint/Body: ‘74 Duster to ‘71 Demon clone with ‘71 front end, Demon tail panel, ‘68 marker lights. Bucket seat conversion, rallye dash conversion, fold down seat conversion, B-body fuel tank
Steering: Power steering, 16:1 Flaming River manual
Brakes: stock BBP disk/drum, 11 3/4” disk and 11x2.5” drum, 13” DoctorDiff cobra kit and 11.7 rear disks
Wheels: stock BBP, 15x7” cop wheels w/ 225/60/15, Enkei RPF1’s 18x9 and 18x10 w/ 275/35/18’s and 295/40/18’s
Suspension: /6 torsion bars and stock springs, 1” bars and stock springs w/ non-adjustable tubular UCA’s and boxed LCA’s with Bilstein shocks, 1.12” Firm Feel bars with AFCO 121 lb/in springs w/SPC UCA’s and QA1 tubular LCA’s with Hotchkis Fox shocks and Hellwig sway bars front and rear
Plus a ton of other stuff, not done yet!
Engines: 318, 340, 340 aluminum heads
Radiator/cooling: stock, 22” Champion, 22" ColdCase with modified stock shroud
Transmissions: A833, TKO600
Paint/Body: T5 Bronze to Vitamin C Orange (Yeah I know that's what Plymouth called it, I don't care.)
Steering: manual, FimrFeel Stage III Power steering
Wheels: Centerline 15x7.5 Convo Pro wheels w/ 225/60/15, Custom American Racing Torq Thrust SL 17x8 and 17x7 w/ BFG Cport Comp II Tires.
Suspension: V8 torsion bars and stock springs, 1” bars and ESPO SPrings w/ non-adjustable tubular UCA’s and boxed LCA’s with Hotchkis shocks, Addco Sway Bars with modified mounts.
And probably more stuff I have replaced, modified, and made to work. Like Holley's shitty TKO mount.
I'll try......
1970 Barracuda Gran Coupe convertible
Factory 318/904/7 1/4 rear. 10" drums all around
Bought as basket case.
O.G. iteration: Stock 73 340, 727, 8 3/4 with 3.23.
2nd: Same 340 with .508 Purple Shaft, Holley Strip Dominator, milled to **** J heads with 2.02, 780 vac. Secondaries, same 727 and no damn stall, 3.91 gear.
3rd: Stock 70 340, same 727, put 3.23 back in. This 340 was plum wore out. Re-rung it anyway. Broke compression rings. ****...
4th: 318 put of a 71 Polara figure 8 car, 340 cam(OMG that doesn't work!), TQ, 727 replaced with 998, 3.23 gear. This served well for a few years. Ultimately, after too many hard revs, the Teener spit a wrist pin clip. Thus, Ka-Boom in the most boring fashion.
5th: 50k 360 out of an ambulance van. 340 cam. Same TQ, Used the 998 with a balance flex plate, same gear. This served very well for a fee years too.
6th: Off the deep end. Quit mud racing. Had all my driveline left. Aluminum headed, 15 to 1, 408. 727 with T/A trans brake and 5000 stall, 4.56 gear. Stock driveshaft and 7260 joints. This is when I started drag racing. Full brake launches, 11.40 times. This is when I learned about "Rules". Slow down or go home. Damn, on to the next....
7th: Stock 76 Chrysler 440 long block, Hughes Whiplash cam, headers, 727 from same engine, 3.23 rear gear. Slow? Yes.....
Still basically the same combo with carb, intake, convertor upgrades.
Not sure yet, BUT, it may end up with my gen 3 426 with a 4 speed........ We'll see!!!
This one is with me forever.....
Bought it in 88 as a basket..... Still going....
