69340
- Joined
- Mar 16, 2007
- Messages
- 260
- Reaction score
- 4
Hi members isearched the forums and found how to get the vent window out of the car. No problem once you find all the bolts etc. My Dilemna i replaced my rusty vent window assembly with a nicer unit. when i removed it i broke the plastic pieces that go into the track that hold the side window into the track. I have aquired new plastic pieces and the plastic/felt track that the have to window slides into. how do i get the whole assembly back together. does the door glass have to slide into the vent window channel from the bottom?. there just does not seem to be enough room to get these plastic guides into the track. i have removed the window stops so ican remove the window out the top but to cant feed into the track from the top. this is on a 1969 dart swinger 2dr. any help would be great.
