[WANTED] Wanted: Pinion angle shims
You can also check your local spring shops . They should have them in stock .
A word of advice. Buy steel shims, not aluminum. Yrs. ago I tried 2 sets of aluminum shims and both eventually broke. Replaced them with steel shims and never had a problem afterwards. The E-bay ones that John posted the link to are good ones. The seller, Dr. Diff is an upstanding member here
