LIMEY VALIANT
Hi all
Here`s my motor. Only had it a short while so don`t know everything about it.
Been looking at Snow Performance stage 2 dual carb water / meth roots blower injection kit .... anyone use it on a similar build ? any good ? what results did you see ?
Here`s what I know
360
8.5 to 1 c.r.
4027596 heads
2 x 4 bbl 600 cfm carbs on 1" spacers
6 psi blower pressure
6.5 psi fuel pressure on 114 octane leaded
This set up ran 11.3366 on fairly mild shakedown run in 2600 lbs Valiant. Pulled heads after to see there was no detonation. Recutting all valve seats, home porting intake and blower transformation plate together with new gaskets all round.
Thanks in advance
Here`s what I know
360
8.5 to 1 c.r.
4027596 heads
Thanks in advance
