BB73Challenger
Snow Performance Part Number 20020
MC/MCS/DOM Water/Methanol injection kit
Stage 2
For gas engines naturally aspirated !!
In Cleveland Ohio
$350.00 plus shipping
Will take cash/money order/pay-pal/looking for drag radials(maybe wheels too plus cash depending?)
Look this up on Summit's web site using the part number and you will see the same kit we have here.
Long story short, I'm changing directions with an engine build.
USED! Has been installed, but never run.
Pump, control unit, reservoir, solenoid were installed but never wired in or powered up.
Crazy, I know.
I have EVERYTHING that this kit came with. Every little nut and washer as well as the large components.
If it's listed in the instructions I have it.
The only potential negative I can think of is since I did have this installed, the 10' of line from the pump to the solenoid then to the plate has been cut - again, I had it installed.
There was ample line for everything to be mounted under the hood.
If you were going to run the pump in the trunk or rear you would need more line anyway.
If you live in the area/will be in the area I have a whole case of Snow's boost juice as part of the deal
PM me and we can talk, thanks
http://i737.photobucket.com/albums/xx15/jsl73challenger/1_zpsab8959d4.jpeg
http://i737.photobucket.com/albums/xx15/jsl73challenger/2_zps87d36bf2.jpeg
http://i737.photobucket.com/albums/xx15/jsl73challenger/3_zps448c5751.jpeg
http://i737.photobucket.com/albums/xx15/jsl73challenger/4_zpsc36e999d.jpeg
http://i737.photobucket.com/albums/xx15/jsl73challenger/5_zps8e420c6d.jpeg
Thanks FABO
Stage 2
In Cleveland Ohio
Crazy, I know.
Thanks FABO
